So I came across a Dana 60 for an e-body and looking to put it into my 1971 Charger. I wanted to run a slightly narrow rearend so I could put bigger wheels in the back. I figure I could remove the stock mounts, add Cass’s (Dr Diff) rear spring relocation kit and make some decent tire space in there. The e-body is about 2in narrower than the -b-body, so I’m sure I can get some big tires under the back. Hope to try for 12in instead of just smashing a 10in wheel back there. Just wondering if someone has done this and if so, how big of a wheel, tires were you able to fit?
