Re: Friends 'low' oil psi 340, only about 10,000miles
[Re: Mopar72Man]
#31746
01/06/07 12:09 PM
01/06/07 12:09 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Issue still remains, in re-reading this reply.
First thing I'd do is try another gauge; then cut the oil filter open and inspect the element for bearing material. Could be bearing clearances too large, oil being aerated, maybe the filter going into bypass. Sounds like the oil has to be cold (thicker) or the pump spun up to maintain oil pressure, which sounds like an internal (pressure) leak. It doesn't sound fatal, but it doesn't sound right, either; mine have always idled hot with at least 30PSI with a stock pump and regardless of mileage.
i'm wondering why if when the motor was first fired. At idle it held about 30lbs hot. Not its dwindled down to 15.
Any other suggestions? Could a faulty pump/spring be the culprit? He has a oil idiot light for 15psi and a autometer gauge. light comes on and the gauge shows 15 at hot idle. so we dont think its the gauges fault. Anything else we can check besides pulling it apart? Its been through a couple oil changes with no change in pressure.
thanks.
If it changed pressure from when it first was run to now, then there is something wrong.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Entire Thread
Mopar72Man
10/22/06 07:20 PM
fastmark
10/22/06 07:27 PM
Mopar72Man
10/22/06 07:28 PM
StealthWedge67
10/22/06 07:31 PM
sleepyhead416
10/22/06 09:06 PM
Mopar72Man
10/22/06 09:10 PM
sleepyhead416
10/22/06 10:46 PM
moper
10/22/06 11:14 PM
CokeBottleKid
10/22/06 11:20 PM
HemiRick
10/23/06 12:21 AM
topside
10/23/06 12:53 AM
Mopar72Man
10/23/06 12:58 AM
sixpaktoogo
10/23/06 01:26 AM
Mopar72Man
10/23/06 01:30 AM
Mopar72Man
01/06/07 03:42 PM
CJK440
01/06/07 04:09 PM
Mopar72Man
01/06/07 04:12 PM
bonefish
01/06/07 07:17 PM
01/06/07 09:45 PM
CJK440
01/07/07 12:49 AM
dogdays
01/08/07 04:36 PM
Challenger 1
01/08/07 05:08 PM
dogdays
01/08/07 05:31 PM
70blackfish
01/09/07 04:25 PM
moper
01/09/07 04:35 PM
Flesh
05/30/08 11:12 PM
Evil Spirit
05/31/08 01:32 AM
3ddart
05/31/08 01:51 PM
Jeremiah
05/31/08 05:01 PM
10/23/06 02:05 AM
Mopar72Man
10/23/06 02:14 AM
10/23/06 02:54 AM
mopars4ever
10/23/06 04:05 PM
10/23/06 02:14 AM
Mopar72Man
10/23/06 02:17 AM
10/23/06 02:20 AM
topside
10/23/06 02:41 AM
HotRodDave
05/31/08 07:23 PM
VS29H0B
05/31/08 09:01 PM
MoparJoe
10/23/06 12:47 AM
Mopar72Man
10/23/06 12:53 AM
moper
10/23/06 04:27 PM
Paul_Fancsali
10/23/06 06:52 PM
dogdays
10/23/06 07:03 PM
darenrt
10/23/06 11:55 PM
Hans
06/03/08 02:37 AM
