As an FYI, I connected the battery, turned on the headlights and checked each fuse with a test light. The only fuse that didn't have power at each end was the fuse circled. In addition, the cigarette lighter was indeed in the car. I removed the three screws that held it in-place and found the double-wire connector attached to the back of the cigarette lighter. I removed the connector and checked it with the test light and no voltage was detected there either. Thoughts on how to proceed with my non-working running lights issue?
