Originally Posted by TheOtherDodge
Originally Posted by NITROUSN
Like this.
I meant they will probably need to be a tensioner between the crank and PS and not so sure how easy it would be to fab it.
You cant run two tensioners. . Are you running a/c? Simple test would be to buy a belt and see how it acts. There might be enough tension on the belt with the one stock tensioner.
