Originally Posted by 73cuda340
I used a caliper to measure the torsion bars and they are in the .892-.900 range. I'll try to see if I can find a part number on them to find out for sure which ones they are.
So according to the chart, you have big block bars in your car now. There is only one set with more capacity. Based on that info, I would not swap out your current bars.
