I'm a drag race guy, not a roundy rounder or sportscar track guy, I left the stock 6 cylinder non air conditioning torsion bars in my old pump gas 1971 Duster, I did use a good set of double adjustable shocks on the front and ended up with double adjustable coil over shocks in the rear, that car worked fine on the street and strip,
![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif)
Best ET was 9.993 at 134.+ MPH cork up with the air cleaner on using Oregon 92 octane pump swill in the 10.75 to 1 comp. ratio 400 block stroker motor, it road and handled fine on the street also
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
