I was flipping threw the news channels last night and i still have not seen the debris field. Guess they don't have time to look over everything to distinguish if it might be a body part. At that depth i doubt anything is left.
The bodies were vaporized. No trace will ever be found of them.
Think about what happens to air in your air compressor. Going from static to 130psi and the heat in that air. Multiply that change times 100 or 1000. Happens so fast, it never registers with the person.
Human body is 80% water?
Water handles high PSI rather well.
I suspect remains suffered from extreme blunt force trauma as the seawater rushed in at very high speed in what has been estimated within 20 milliseconds?
An analogy might be similar to dropping a water balloon into deep water, it would be impacted little any at depth it sank to, even if it had any air trapped within.
