Originally Posted by Dabee
What is the amp rating on you alternator. I had an over heat issue on one of the street rods. Replaced the 110 amp alt with a 180 amp problem fixed. With the electric fuel pump, fan and everything else drawing power the 110 couldn’t handle the load resulting in reduced fan speed.
work scope up
