iagree In my nonexpert opinion, you need more idle timing not less….. 20° temp drop through the radiator sounds excellent to me, I’ve heard that even 10 degrees is good enoughshruggy You have your electric fans pushing? Do they block air going down the road?
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
