One thing to remember is the piston is running away from the intake valve on the intake stroke, and then during the compression stroke some turbulence is good to keep the air fuel mixture mixed up. The reasons for quench pads on pistons and a quench area on closed chambered heads. I guess it must work as I don't know of and aftermarket wedge heads without a quench area in the chamber.
