Re: Quest for 1,000 hp, back on the dyno!
[Re: Cab_Burge]
#3137606
04/13/23 03:47 AM
04/13/23 03:47 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I've never ran any motor of my own or helped tune a straight alcohol motor so I know nothing about them as far as Lamda or AFR numbers and what they like to make the best power E85 is my current choice on my race motors, I may end up trying straight methanol alcohol on my next deal if pump E85 doesn't work well I'm hoping E85 will work well with NOS first and later on 25 to 30 lbs. of boost Good luck with it, Cab. i do know that pump E85 at only 108 octane and has less cooling ability to avoid detonation versus straight methanol. for a boosted application running that much boost, i would be real carefull with E85 pump. It may not do well resisting detonation where a methanol motor you just run it VERY fat, like 3.4 versus 5.6 for a modest normally aspirated motor. also power will be lower a touch( 3 to 5 percent?) with e 85. but you don't need to take 35 gallons with you for a race weekend, as you might with methanol if you make a lot of passes. i average 2 gallons for warmup and over 1.5 for each pass on methanol.
Entire Thread
gregsdart
04/12/23 09:06 PM
71Demon528
04/13/23 12:43 AM
Cab_Burge
04/13/23 03:30 AM
gregsdart
04/13/23 07:23 AM
Cab_Burge
04/13/23 07:36 AM
gregsdart
04/13/23 07:47 AM
gregsdart
04/13/23 08:47 AM
powertrip
04/13/23 06:28 PM
gregsdart
04/16/23 03:00 PM
440Jim
04/13/23 07:19 PM
Al_Alguire
04/13/23 08:30 PM
Uberpube
04/13/23 11:36 PM
gregsdart
04/14/23 04:09 PM
Cab_Burge
04/14/23 06:39 PM
Al_Alguire
04/14/23 08:41 PM
gregsdart
04/14/23 11:58 PM
birdtracker
04/15/23 12:20 AM
Cab_Burge
04/15/23 01:44 AM
gregsdart
04/14/23 01:58 AM
HardcoreB
04/14/23 11:55 AM
gregsdart
04/14/23 12:42 PM
Al_Alguire
04/14/23 03:46 PM
gregsdart
04/14/23 03:47 PM
gregsdart
04/15/23 10:17 PM
