Is this with race gas or? If gasoline it's pretty fat work twocents
I'm thinking if it is gasoline, you might gain another 25 HP by leaning the AFR down so it is around 12.6 to 13.5AFR shruggy Lean is mean up devil Be careful on the timing and spark plug heat range also, sneak up on it, one jet size at a time or small bleed changes, not hit it with a big hammer tsk
