Any of you guys use spacers on the rear wheels on your Mopars ?
One thing that always annoys me on B bodies is most wheel/tire combos look lost in the rear arches unless going for some big mickey thompson/Hoosier size
I like the look where the tires sit flush with the rear arch
Just thinking spacers might be a simpler cheaper option rather than wider drag tires
Any thoughts ?
Yes, I always space the wheels out until tires are almost rubbing for photo shoots/show cars. For a daily driver I bring the tire in about an inch so it doesn't rub when cornering, going over bumps, etc. Here is how I had my Duster set up.
