Mine did the zero fuel pressure thing but still ran. Changed out the lift pump and still no pump action. No power to the pump and no obvious reasons why so I assumed the driver was toast. Found a switched ignition only power source in the fuse box and powered the lift pump from there. There is a potential safety issue with the pump running with the ignition on regardless of the engine running or not. Bleeding the fuel system is a snap tho with the constant flow.
Kevin
Thanks, above makes sense . . . although, if have the service manual and are able to "duplicate" how the ECM fires up the lift pump, then could duplicate, OUTSIDE the ECM . . .kinda of like external regulator for the alternator . . .
