Hello,
My 1964 dodge custom 880 steering wheel and car (feels like back tires) shake when I take off. Once I go into next gear and over 30 mph, the steering wheel and back body wobble/shake stops. When I am cruising on the highway, the car drives very smooth. However, when I begin to stop, the car vibrates really bad. The car's front suspension has been done (tie rods, ball joints, bushings, etc). However, I have the original ball and trunion drive shaft and the boot is missing but I have a new u joint. I dont know the condition of my motor or transmission mounts. Lastly, I have drum brakes with one line all around. Right side rear back drum brakes gets really hot than the other drums and I can't get them off?? Should i consider a driveshaft conversion or can bad rear drum brakes cause this problem?
