Originally Posted by Ari440
What are the rocker arm ratios on a Hemi
1.5 ?
Anyone know if the Ray Barton rocker set up can be had with custom ratio rockers? I know 1.5+ is common, but I'm wondering if 1.4 or 1.45 could be made to order? Additionally, is there any downside to a ratio under 1.5 assuming the lower net valve lift isn't needed?
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
