Originally Posted by Dragula
Originally Posted by an8sec70cuda
Originally Posted by Ari440
Do you think 680/270 to big for 10.1 comp on a street motor
No.
No.....But its no subtle either....What's beautiful about a Hemi, is its resistance to detonation....I would turn the compression up to 12:1 or 13:1 if I was building it as a pro-street or a little raced street car. If you keep the timing in check, you will never have an issue.
Better off getting 12.1 comp pistons then ?
Or stick with 10.5 comp pistons
Thank you for your help every body
1.39 9.85 - 137 mph
