Originally Posted by A12
Originally Posted by SNK-EYZ
Pretty sure that on a 69 Charger Daytona the front fenders are literally 70 Charger fenders with the headlight buckets removed.
I believe the hood is a modified 70 Charger hood.
Are they the same parts also used on the Plymouth Superbird?
No the Super Bird uses 1970 Dodge Coronet fenders & hood that they modify
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
