That doesn't make any sense to me. What is the bob weight of the current parts going into it? 12 oz, ie 12x28gm add? That's preposterous. With heavy metal already in the crank? Not adding up? S/F....Ken M
^^^^This^^^^ I have done a few old fuel cranks, the last one was a center counterweight and I had to remove 512 grams, it made me sick to drill into the heavy metal. I can't imagine adding weight to a heavy crank.
Do you have the bob weight numbers?
Joe
Without Data, you’re just another guy with an opinion.
