I get 140-180 out of MT pro bracket radials , mostly transbrake . Hoosier drag radial slick im at about 60/70 passes so far . Not sure i will get the same as MT BUT the Hoosier is quicker . Possibly as they are 1/2" shorter . They are better foot braking for me seem to not like tbrake as much . They are about 10lbs lighter and i am currently using them on a 8" rim as i only have 1 pair of 10s . I need a solid burnout or i turn
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
