The fenderwell headers are most likely killing power. I've seen them lose 50 hp on a race engine. My guess is still that the heads are the problem but it could be something else. Double check everything to see if you have any "dumb" mistakes and then go from there. If you want to make more power you'll most likely need to pull things apart and take stock of what you have. Otherwise just run it as is.
