Add some race fuel and bump up the timing. Otherwise, I'd be looking at a cam change if you want to stick w/ pump gas. Do you have a reconmendation on which direction to go with the cam? Fast68plymouth here on the board is the cam guru. Porter Racing Heads 802-951-1955
