Originally Posted by Andyvh1959
Thanks. Another clue is if the battery only has three caps on top instead of six. 6-volt batteries only have three 2-volt cells. 12-volt batteries have six caps.
The generator should tell you all you need to know, someone may have put the wrong battery in it and that's shy it got parked?
