Originally Posted by Cab_Burge
I've never heard any mention of a torque number to use on them, measure the thread diameter, I'm thinking it is 3/8 course thread grade five fasteners, but make sure scope and look up the torque for that size.
I wouldn't hesitate to use between 25 and 30 Ft. lbs. with red Loctite
iagree
I would also Loctite (Red or Blue should be fine) the shifter mounting bolts. Do remember to heat the fasteners on the mounting plate if you need to remove it later. I have had the allens round out if one tries to remove them without a little heat. it doesn't take a lot but really helps in removal without destroying the fastener wink
