Originally Posted by Cab_Burge
The early NP833 main cases and tail shaft housing are cast steel, the adapter is cast aluminum with two mounting holes through them to hold the adapter onto the tail shaft housings wrench
Some Serviceable Loctite and that will be fine, with a good tightening by hand. No need to over-think such things.
