I pulled one pump apart after it failed and the flow control valve was recessed into the housing. I had to use a magnet to get it to come out and when it did, the spring "unstuck" and popped out a moment after. It is possible that the failed pumps still work if the spring and valve are not stuck in the fully compressed position.
Still, I was frustrated by the repeated bad results so I pulled it and boxed it up.
