Alternatively, are there any issues with a B3 relocation kit? I've heard a couple people mention the bolt holes in the rocker arm stands are shallow on the Trick Flows and studs are recommended, but I don't see a way to use studs with the B3 kits.
Thanks, Nick
Am I missing something here? Why would studs fit the B3 kit any different than bolts?
In theory, there is no difference between theory and practice. In practice, there is.
