There are various ways to do this but it all depends on what tools you have and how high of space you have to work with. I have a bridge crane in my shop so I pick up the car and lower it over the engine. Then I pull the engine up into the car and then I lift the K frame into place. If I had other tools I would do it a different way. For instance I've done the same thing with a two post lift but you have to do it a little differently. If you have a cherry picker you have to do it slightly differently.
