I recall paying $8-9$ a quart when replacing fluid in my neon. If you think $11 a quart is insane, be greatful you don't have a ZF in any of your rides. Non serviceable filter unless you buy the Dorman pan ($250.00 avg from my searches), mopar fluid runs an astronomical $40 avg PER QUART. I've seen some ZF fluids at near $100/qt and that was before all the poop hit the fan, probably $150/qt now.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
