Originally Posted by Andrewh
thought that the connector going first was the whole point?
I had one that melted it off the battery first before anything else burned off.
I have also had a short vaporize an inch of 10 gauge. plus a couple inches of insulation on each side.
Lets say the connector burns so then the cable is flopping around looking for more trouble what can you do but have a bracket holding the cable or a tether.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
