I must have a short to the chassis from a chafing rub through a frame or back seat blockoff and will hunt it down.The short melted a 0g copper lug to the - battery post and put a hole in the battery case from the heat too close.I could use a better battery connector to the post but part of the problem was this was not tight on the post and was no help to the ground.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
