You could use a 71-74 B body shifter and plate if you don't have an E body unit. I have used an earlier B shifter before on my E body extension but I made my own linkage from tubing and heim joints. It can be done on a budget and you probably have enough stuff in your stash to make it work.
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
