Originally Posted by eightlitermopar
Originally Posted by GTX MATT
Pull the bearing caps and see whats in there. Post pics.
Does it spin easy?
It does spin easy. Even by hand, the short block spins freely. My next day off is next week, I will pull the caps and post pics. Connecting rod ends are NOT discolored.
If none are spun and the crank looks good put it together and run it, or put bearings and rings in it and run it. If it was oil starved for significant time you will see it, and it probably wouldn’t spin easy.
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
