I would look at the internals and see if it's all stock. The timing gear may be an indication that is is but the engine is 45 years old and you don't know it's history. IF you can get away with a hone and new rings you will be saving a lot instead of bore and pistons. Same goes for the rest of the engine, If it's needs replacing now is the time to do it.
