OEM RB block, Comp roller cam & lifters, new Indy EZ-1 cylinder heads, Hughes 1.5 rockers, 3/8 push rods.
Because of the arc that the top of the push rod travels, from about half of the lift through max lift and back down to about half lift, all eight intake push rods rub the cylinder head behind intake mounting flange. Some more so than others, but all to some degree. In the valve closed position, the push rods are almost centered in the push rod holes. Other than removing the heads and material removal, is there any other solutions, such as going to Harland Sharp rockers? Is this a common problem with Indy heads? I can move the rockers side to side with shims to some extent, but what about in and out movement? Any way to decrease the travel arc?
Thanks, Brian
I'm running Indy EZs, I think the pushrod holes were clearanced. Harland sharp rockers also. Maybe Fast68Plymouth will chime inn. That's who I got my heads from. B3 racing shaft adjustment set up might help. Maybe he will read this.
