Pics of the lightened K frame. No motor mount, trimmed the box mount and used moly tubing. Cut all the flanges off. Large oil pan access. The moly strut rods were made by cutting off the stock ends and reducing there diameter to fit snugly into 3/4" moly tube. Then welded back together. Steering shaft is also .090" moly tubing, The front fender braces and hood latch support are 3/8" moly tubing. Doug
