Originally Posted by PhillyRag
Just saying the water level should be more important with the Authorities right now, since it's critically close to closing down power generation.
As is usually the case: they're be reactive rather then proactive. Should be making plans for when/if that occurs.
Nexus? Do you think people are going to be upset if a 50+ yr cold case isn't solved, or when there are drastic power cut backs imposed across southwest?
iagree Solve the water / looming power issue then worry about ID'ing the remains found. Hey maybe Hoffa will surface (no pun intended) but doubtful twocents
