Originally Posted by IMGTX
Thanks.
I will bend it back down.
I can honestly say I have watched more videos on using a table saw than on any other single purpose.
I had a friend who had 4 fingers shortened when I was younger. He left me with a permanently etched paranoia about table saws. So all the warnings and cautions are not being ignored.
I have learned a lot from this project.
Thanks again for the help up
Why bend it down. Find out why it is not working correctly. If you look at other plates they have a finger hole to lift the plate out. Yours does not. That tab is spring loaded both ways.One holds it up for plate removal. The other way is to lock it into the table. Why ruin it. Fix it and understand its purpose.
