The block I am prepping to replace my cracked Original has HUGE chamfers. Some will come out with decking, but I will still need to use 4.590 bore head gaskets to keep the fire ring away form the edge.
496" @ 4.360, 10.4:1 compression, Ported Eddie RPM's, little over 600 HP.
Fel-Pro 1105's and 1039's appear to be identical except for the comment about a pre-flattened steel ring, and the obvious dual bolt pattern on the 1039.
What is the difference? I would go Cometic, but nothing is available in-stock on my time frame. I looked at the 8519-PT1's, but they are "only" 4.5" bore.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
