RB Head gasket differences #3064842
08/03/22 09:52 AM
08/03/22 09:52 AM
Erda, UT
67Charger Offline OP
Erda, UT
The block I am prepping to replace my cracked Original has HUGE chamfers. Some will come out with decking, but I will still need to use 4.590 bore head gaskets to keep the fire ring away form the edge.
496" @ 4.360, 10.4:1 compression, Ported Eddie RPM's, little over 600 HP.
Fel-Pro 1105's and 1039's appear to be identical except for the comment about a pre-flattened steel ring, and the obvious dual bolt pattern on the 1039.
What is the difference? I would go Cometic, but nothing is available in-stock on my time frame. I looked at the 8519-PT1's, but they are "only" 4.5" bore.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: RB Head gasket differences [Re: 67Charger] #3064866
08/03/22 10:57 AM
08/03/22 10:57 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I assume either of those Fel-Pro's would be fine
2011 Drag Pak Challenger
Re: RB Head gasket differences [Re: 67Charger] #3064879
08/03/22 11:26 AM
08/03/22 11:26 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have the same issue with my block. Keeping the head gasket from intruding beyond the clamped surfaces of the head and block on my motor will likely take a custom copper head gasket and a die grinder. The combustion chamber on the head has had the valves unshrouded in the same spot. I may actually have that area welded up and reshaped to better match the bore notches.
