Griner foot brake valve body models 1222G05 & 1222G05B
where B is band on in 1st both have enlarged fluid
passages and a 12mm check ball for 3rd to increase fluid
Volume. Also pressure is calibrated higher. The throttle
pressure/kick down valves are eliminated to provide
larger fluid paths. Third gear path is shorter than TA
Cheetah model.
