Originally Posted by Transman
Originally Posted by 727specialist
The trans is in first and reverse when the brake is on. The high gear clutches have to release quickly. If they don't that can affect the 60 ft. Keith
Correct. And how does one release the front clutch quicker through the valve body?
The Griner valve body dumps the pressure through the solenoid and the hole drilled in the high gear drum. Keith
