if this means anything or not; i have a '66 street hemi converter behind a 440. the 440 has some mods, eddie heads, ch28, and a 238@.050" solid cam. the converter flashes at 2300rpm in a 3900lb b-body with a 3.23 gear. there are no mods to the converter.
i would think that same converter should stall at lower RPMs on a stock hemi. so 1800 should seem about right?
ill go check the mopar chassis bible as suggested.
