Dealt with my last tire failure. Going to a LT truck tire. Really don’t care what the states think.
As long as the rating is equal or better than OE knock yourself out! My limited research prior to going to a G rated tire (max load single 4400lb @ 110psi) was that people were seeing about the same rate of tire failure with the LT as the ST. My G rated tires have L rating up to 75mph speed.
Wes I see they have a 15” 12 ply…..
https://www.greenballtires.com/brands/greenball/tow-master-asc
