Originally Posted by mgoblue9798
I am considering buying a set to possibly use on my 440 in my truck.
Any idea if these require the use of special valve covers?
Would there be enough room to run a master cylinder and brake booster?
Are you talking about the Chrysler 300 manifolds? If so I believe they require matching exhaust manifolds to heat the carb instead of the exhaust crossover.
