68 Satellite .
rolled lip . Stock spring location . Factory XHD springs . Standard width diff .
8"rim use a 4 1/2 BS
10"rim use a 5 1/2"BS
I have run 295/65R15 @ 30.3/3"tall but slight rub on dogleg .
I shimmed spring back 1/4"to make it all fit with no rub .
I run a radial PBR 29.5x10.5R15 , actual height is 30"
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
