Of course raising the front won't raise the rear
Also, reading the o/p's topic he asks about ONE side being lower than the other.
I raised the front left on mine in order to lower the right rear some as I was looking to even my rear. My right side was higher and driving me nuts. I did everything from swapping the leaf springs to adding a leaf spring pad on one side and other things. So I was able to balance out the unevenness some with little tweaks with front end. Lithium battery instead of the almost 50 lb Interstate sitting in front left (11 pounds) T bar tweak and things are MUCH better and the stance looks good now. But I'll write it again; if you lift the left side REAR, the right side REAR the right side will come up almost the same amount. I learned.
