My 69 GTS that I have owned for almost 44 years now had the top core support changed in 1979 when I wrecked it into a light pole. There are no numbers on it as my original was destroyed at the place where the numbers were. Lots of cars had that happened to them back in the day. I don't care what anyone says about my car, it is still numbers matching...
You might believe that, heck you might be right.
You won't get matching numbers money for it though and in the end that is all matching numbers is about.
I cut apart a 1968 Dart GT and the core support had no numbers on it whatsoever. It was 100% original and I knew the owner from day one. If you believe every Mopar came from the factory with the proper numbers stamped on them then I have a chunk of nice dry land in Florida I will sell you.
I am sure you have seen the factory VIN issues that are out there. A buddy had a 71 "V" code Roadrunner where the "V" was missing in the VIN, only 12 numbers instead of the requisite 13...
