Originally Posted by topside
I didn't see where anyone posted on this, sorry if I'm reposting...
Apparently a customer bought a "Cuda V-code" and brought it in for restoration, but after looking it over, Worman finds out it's a re-bodied Gran Coupe.
Rad support & cowl replaced at some time, GC trim holes welded & ground...someone definitely intended to re-body and "upgrade" the car.
OEM dash VIN rivets & apparently pad.
Basically called the car out - with the V-code VIN - on national TV, then says the customer wants to proceed with the build. Yikes.
Seems to me that's flirting with trouble even further than the mostly-AMD '71 black Cuda build, apparently also a customer request.
Well, at least it will be documented on tv as a tainted car.
China is the enemy.
