In my eyes a waste of time. If your installing ladder bars you need good shocks anyway. That means you're buying a cheap pair of coil over springs instead of floaters. It's a no brainer. Now if it's already set up with floaters maybe?. But chances are the leafs are to stiff anyway. The coil springs are cheaper than monos. Doug
yes a complete waste of time
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
